Not Considered items in Hazop study??
Friends,
I recently came across a HAZOP study which included the following in NOT CONSIDERED list:
1. Failures of Manual valves
2. Operator Error
3. Passing of NRVs and PSVs
Is it OK?
Pl give your views.
Thanks in advance.
2. Operator Error
Is it OK?
Pl give your views.
Thanks in advance.
RE: Not Considered items in Hazop study??
The idea of a HAZOP is to identify hazards and risks to a system. To specifically list the 3 hazards/risks mentioned indicates there was some sort of thought process that went into it, I don't understand what it was. Perhaps they were covered under a separate risk assessment, but if so it would have been prudent to note.
A HAZOP, risk assessment, constructability review and other similar processes will only provide optimum results if the proper personnel are gathered to do them. Garbage in = Garbage out.
Greg Lamberson, BS, MBA
Consultant - Upstream Energy
Website: www.oil-gas-consulting.com
As far as I know, the failure of manual valves should always be included in HAZOP scope. Operator errors is quite a bit large area for risk analysis and is usually carried out separately - mostly included in extended plant operating manual, incidents & near misses worksheet or some other type of risk assesment. For NRVs and PSVs issues I cannot recall they were being part of HAZOP risk items.
http://antwrp.gsfc.nasa.gov/apod/astropix.html
There are several sources that address HAZOP's - API 750, Management of Process Hazards; the AIChE-CCPS book,
Guidelines for Hazard Evaluation Procedures; and OSHA 29
CFR 1910.119. Also API 580, Risk Based Inspections.
There are also other methodologies besides HAZOP's that are used to achieve quantitative risk assessments - Failure Mode & Effects Analysis (FMEA), and Fault Tree Analysis. And there are just standard design risk assessments.
That is why I mentioned above that because those items were specifically mentioned as not being addressed by the HAZOP, chances are they were addressed by another means.
there is sometimes quite a bit of debate in HAZOP's of what constitutes "Double Jeopardy" and perhaps this is what is referenced.
if it is a HAZOP that is worth its salt, it should have the names of those involved and you should ask them.
Sabatoge should be covered under a security risk assessment.
http://virtualpipeline.spaces.msn.com
"We can't solve problems by using the same kind of thinking we used when we created them." -Albert Einstein
