Rotating Viewports
Rotating Viewports
I created a viewport in Paperspace, Release 14 "plain vanilla ACAD". The model needs to be rotated in the viewport along a road surface so the road is horizontal on each sheet. I know NOT to rotate the model in modelspace... how do I rotate the model in the viewport on each sheet, do I use a view command, UCS changes ???
RE: Rotating Viewports
MVsetup,a(for align),r(for rotate),pick point inside your viewport, type in the angel you wish to rotate. Don't change to ms while performing this command. The down side to this (if I'm not mistaken)this will chang all the viewports in that layout to the spcified angle. Could be wrong about that though.
