Concrete construction
I am working for a company who is installing cabins, which are ISO shipping containers in general description. The problem is, that the original plan was to install them onto reinforced concrete rafts. However, citing cost constraints, the program manager has changed this and substituted four un-reinforced concrete blocks, one at each corner.
The blocks are made by local contractors using un-supervised labour and local materials, (lets call this the Middle East)
The geographical location has serious seismic events and is a major risk. The blocks are not footed into the ground at all, just placed into position, the container is not secured to the blocks in any way.
So am I seeing problems where none exists? with using four un-reinforced concrete blocks of questionable quality to sit six tons of container on, in a seismicaly active area. Oh! people will be working in these, not to mention that the containers have vital, sensitive equipment in them, the failure of which will have serious ramifications.
Any thoughts on this ?
RE: Concrete construction
i suppose someone (program manager, client, military, whoever) should evaluate what kind of performance/life expectancy they're expecting versus the cost of building the thing as well as the consequences of critical equipment failure (which could result anyway during a seismic event depending on the ruggedness of that sensitive equipment).
good luck!
Richard A. Cornelius, P.E.
WWW.amlinereast.com
