good structural book
my background is heat transfer. i currently own a concrete construction company and need to brush up on structural behavior, retaining wallls, loading, etc. the basics are what i am interested in. i am very computer literate, so an inexpensive piece of software is not out of the question. any asce books / publications recommendations? thanks...
RE: good structural book
This book is typically purchased by engineers about to take the PE. I forewarn you that it is by no means a comprehensive treatment of structural engineering, but it does go through many basic design procedures.
The one aspect that is completely lacking is structural analysis (you indicated that you would like some literature on loads, etc.). The only books on this subject with which I am familiar would probably be too technical for someone just looking for some basic concepts, so I'll reserve that recommendation for someone who may know of a better book.
You may want to look on amazon.com and read the feedback- this should at least give you some idea of the audience for which the book is intended.
http://www.retainpro.com/
Retain Pro is a retaining wall software that comes with a nice manual AND a book on retaining wall principles of design.
https://www.asce.org/bookstore/book.cfm?book=8061
http://
BRAJA M. DAS for Retaining walls and footings.
As for not foundation concrete...
You might like
Reinforced Concrete Mechanics and Design by James G. MacGregor.
http:/
