Straighten Aluminum plate for DI printing Industry
Eran,
Our company develops and markets plates used at the offset DI printing industry for machine such as Karat 74 DI of KBA. We developing a new product based on Aluminum sheet. The Aluminum alloy type is 1050A H18 and thickness of 0.15mm (0.006 inch). It's not a gouge size but a millimeter standard. We receive the Aluminum Sheet as coil (coil width 770mm and diameter 1000mm). At the end of the process we cut it to pieces/plates. As a results of the sheet been at coil the pieces have an arc shape that we want to eliminate.
We are interested in a machine that can straighten the Al coil And plates. Most of the professional leveling machine builders can't handle material that thick (the minimum they can is 0.4mm). I would like to know what is the process and technology for straighten 0.15mm Al sheet and information on a company that build machine for the job.
Regards.
