Can i use MSS SP 97 Weldolets in PV with out Calculations?
For Nozzle Branching Is it permitted to use MSS SP 97 Weldolets in Pressure vessels with out calculating, but based on the standard pressure and temperature limts(like using Standard flanges).
Our vessel OD and Thickness matches standard Pipe Dimension.
RE: Can i use MSS SP 97 Weldolets in PV with out Calculations?
Weldolet is a proprietary trade mark of Bonney Forge. According to this literature... http://www.bonneyforge.com/OletCat.PDF , weldolets are rated the same as seamless pipe.
