Exceptional Power Generation Density Required.
Greetings,
I am in the process of determining what kind of generation system is best for an application. The application is in an environment that has fluctating temperatures from -60F to 110F. My question is, does anyone know of a generator product or technology that has the capability of approximatly 1kw per pound within this type of environment? Because of the temperature and high power generation, any permanent magnet based generators I believe are out of the question, which so far are the only ones that I know can produce power with that kind of energy density. I have seen some products that use amorphous metals but still don't meet the needs I require. Thanks for any help.
-Kris
-Kris
RE: Exceptional Power Generation Density Required.
Keith Cress
Keith Cress
Maybe your wish list.
Is this under the hood?
How much total power.
Voltage? 12, 42?
Keith Cress
Keith Cress
http://www.calnetix.com/index.htm
