Please suggest tolerance scheme.
Hello everyone,
I have the following situation and I would appreciate if  someone can suggest a tolerancing scheme for the following group of holes: I have three holes. The circular outside boundary of the part is not important. The three holes are inline. The top and bottom holes have a tight diameter tolerance. The center hole does not. The center hole is located midway between the top and bottom holes. The center hole can drift a lot perpendicularly from the plane formed by the top and bottom holes. However the position of the center hole to the midpoint must be tight (see attached sketch).
I am thinking of making the one of the sides of the part where the holes are datum A. Then, making the top and bottom holes a single datum. So, I apply a position tolerance to these two holes relative to datum A and make them datum B. How do I use TP or symmetry to dimension the center hole and assign the requirement described above?
Thank you.
jv
RE: Please suggest tolerance scheme.
See fig 5.41 on p. 139 in the standard. This is how you position bidirectionally.
Powerhound, GDTP T-0419
Production Supervisor
Inventor 2008
Mastercam X2
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
Hi JV1
I agree with powerhound.
desertfox
