Eccentricites generated in "pin-ended"edge columns
I'm involved in the design of a building which has concrete flat slabs supported on internal walls and perimeter columns. I had thought that one could consider the columns as pin-ended and just design for moments due to "nominal" eccentricities - but the longer I think about it the less sure I am...
I'm interested to know if you know of any design guidance or research relating to the moments generated in "pin-ended" edge columns due to the rotation of the slab and the consequent change in position of the point of load application.
Perhaps it is a bit of a theoretical question, but nonetheless I'd be very grateful for any pointers you could give me.
RE: Eccentricites generated in "pin-ended"edge columns
if the slab rotates wouldn't that mostly change the direction of the load, producing a side component, which would change your column into a beam-column ?
mind you, if the slab rotates that much, is the building good for anything ?
probably not worth 2c ...
My experience is that they usually don't amount to much, but there are exceptions, so should be looked at, at least briefly.
