Does this component require Impact testing?
Ring joint gasket has one weld Joint.
Material soft iron
Service temperature -46 Deg C to + 153 Deg C
Is it required to impact test the base material (It is possible to extract 10 x 10 x 55 specimen)
Is it required to Impact test the weldment (In te PQR, is PQR required?)
Does the gasket material warrant impact test at all?
Material soft iron
RE: Does this component require Impact testing?
