Calculate Max Flow through failed PCV
I'm sizing a PSV for a failed regulator case. We have a 600# class system upstream of the PCV, and a 300# class downstream. The fluid is hydrogen, and we've determined that the max upstream pressure is 1350 psig, and the not-to-exceed pressure downstream is 450 psig.
This is a 1/2" tubing line and the regulator is a small Jordan JPR regulator. The product data sheet gives Cv for the valve, but no Cg. I've been looking through my Crane, Fisher Catalog 12, and GPSA manuals trying to find the right equation, but I keep running into roadblocks.
For compressible fluids, Fisher gives an equation that is close to what I need, except that I need a value for XT. This value corresponds to the type of valve, and no such value is given for the Jordan JPR PCV. If I had XT, I could finish the equation. Is there a rule of thumb for values of XT?
Likewise, Fisher gives an question Cg = Cv/C1, however C1 is explained: "C1 of the valve under consideration". Another value dependent on the type of valve, which is not given by the Jordan data sheet.
A third equation that I was given by an associate is q = P1*Cg, where P1 is in absolute units (psia). I do not know where this equation comes from, and I do not know the units of q (scfm, scfh, gpm??) Can anyone tell me where this equation comesm from?
It appears that I need to get either a C1, Cg, or XT value out of the valve manufacturer. Is there another way to calculate what the max flow through this PCV? Is there a rule of thumb for XT or other values? If I cannot get C1, Cg, or XT is there another method that will give a usable value for flowrate through the a failed/fully-open Jordan PCV?
I appreciate your help. Thanks!!
Onwards,
Matt
RE: Calculate Max Flow through failed PCV
With the ID of the tubing and Cv of the PCV, you have all you need to get a K for the PCV. In Crane, Equation 3-16 can be rearranged to K = 891d4/(Cv)2.
Then, combine the K's of the entire system and use your preferred version of Equation 3-20 like in Examples 4-13 and 4-14 to calculate the flow rate for your scenario.
Good luck,
Latexman
Assuming choked flow you can use:
W = (Cv*Cf*P1*SQRT(Gf))/(54.4*SQRT(z))
W, mass flow rate [t/h]
Cv, Valve flow coefficient
Cf, Critical flow factor (use 1)
P1, Upstream pressure [bara]
Gf, Specific gravity at flowing temperature
z, Compressibility
Latexman, my guy confirmed that there is a reducer before the PCV which reduces down to 1/4". I will research your answer. Thank you!!
While I have your attention, I was sent the source of the third equation I mentioned above. Q =P1*Cg, where Q is in SCFH. Does this equation pertain only to the Fisher 95, or does it apply to all pressure regulators/control valves? I've searched but been unable to find a resource to support this equation beyond the 95 Series. Any thoughts?
Onwards,
Matt
our relief device "experts" like to look only at the PCV and apparently think it has a 6" supply line and an 8" outlet based on the max flows they predict!
- Hope you have considered maximum upstream pressure (PAH or PAHH)
- Credit may be taken for small ID piping/tubing as recommended by Latexman
- As flow passing a CV is dependent on valve design and construction, thus some vendor may have dedicated set of equations and parameters used in estimating maximum load. Using vendor A set of equations for valve manufacture by vendor B may not be suitable...
- Using common methods e.g. ISA, K factors, etc would only be recommended during preliminary design phase. However, it shall always confirm with the selected valve from a manufacturer by using dedicated equations. On the hand, conservative rate estimated using common method can always be taken.
JoeWong
Yep, that's pretty much what I thought. In the past, in the absence of information I used Crane to conservatively estimate the flows. I am still in communication with the manufacturer and I hope they will soon provide me with the data I need. It will be a very small PSV, but we need it nontheless to protect the system.
Thanks to all for your responses.
Onwards,
Matt
