Negitive Parameters
Negitive Parameters
Negitive Parameters
I need to create a parameter that is referanced from an offset dimension of a coordinate system.  I use a relation to create the parameter.
Relation
X_VALUE=d3
Parameter
X_VALUE  Real Number 2.000 <----Should be -2.000
It works but only untill I regenerate twice(once to regenerate the parameter, and once for the assembly).  Is there anything I can do to keep this dimension negitive??  Any help would be greatly appreciated.  Thanks
RE: Negitive Parameters
Use
$X_VALUE = Value
to retain the negative sign.
Usually the relations editor or modify dimension dialog box will give you a tip like use $d## for negative dims or something similar.
Michael
guess this is a case where the ptc.com forum came thru first
Wis..... Brrrr  winky smile
I tried what was suggested, but I end up with the same result. Is there anything else that I could be missing that would fix my problem?
off the top of my head a if then check comes to mind something along the lines  of;
if d3 > 0 then d3=d3*-1
if d3< 0 then d3 = d3
now the syntax isn't proe-ish more vb like
so you'll need to dig around to get the end if's right and the == and so forth.... but I do think that would keep it negitive...
I think that will work as you are referencing a csys... not a datum.
there is that order process
http://www.synthx.com/tom/sy_tip_0004.htm
kind of a side note but it does bring up the regen 2 times deal.....
you might throw in a skel. to get around it tho....
is the neg. csys ref in part level or assy.??
The negitive dimesion is on the assy level.  Its a csys offset from another csys.
from knowledge base... which I'm guessing you have already been there;
The solution is to add a dollar sign ($) in front of the dimension parameter when entering the relation. In this example, the relation would be edited to now read:
$d10 = d1 - d2
Now, as shown in Figure 2, the dimension will update properly. Please note that the configuration option show_dim_sign is set to yes to allow the dimension sign to be displayed.
again the $ sign
http://www.synthx.com/tom/sy_tip_0305.htm
I'm not seeing a val function for proe, in VB it takes the value of a string which you could keep neg. that way. as it would be a literal string until you converted ...sorry
could it be;
no doubt your PIA level is high with this... but might be worth a shot
