Changing Drawing Paper Image
Since I installed SW2008 I noticed that drawings have a picture to make it look real.  It kind of looks like crinkled paper.  Where is the option to change the image used?  I've looked in the help but all I can find is the background image which is behind the paper space.
RE: Changing Drawing Paper Image
Tools->options->colors...select 'use specified color for drawing paper color. This will remove the crinkled effect and apply whatever color you've chosen from the options located above.
Jeff Mirisola, CSWP
Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
Do I infer from your request that you are not awe-struck and inspired by the new "drawing-sheet-that's-been-retrieved-from-the-trash-can" look????
cheers
I like it. It looks like the way it comes back from the checker. I would like to see one with coffee cup stains.
Chris
SolidWorks/PDMWorks 08 1.1
AutoCAD 06
ctopher's home (updated 10-07-07)
ctopher's blog
Yes, those are perfect!
I have seen those before but forgot about them.
Thanks!
Chris
AutoCAD 06
ctopher's blog
I didn't necessarily want to get rid of the picture, but I did find what I needed from the link you gave, thank you.  I expected it to be similar to changing the document background.  I geuss that's why I missed it.
oooooh!  I like the weld spatter look of the second pic.  Funny, my check prints always come back bleeding from the checker =(
dsgnr1
