304 threaded into 15-7
I have a hand-tightened "plug" of 304 being used in a 15-7 condition A, 7/16-20 threaded hole. Do I need to be concerned with galling between the two? I have never worked with 15-7 material before.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
RE: 304 threaded into 15-7
Yes, galling will be a problem.
Plymouth Tube
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
