High Voltage Lines Dangers
What are the dangers of living next to high voltage electrical lines?
RE: High Voltage Lines Dangers
Also, do not touch or come close to conductors which fell on the ground close to the transmission lines.
The main effects of intense fluctuating (a/c power)magnetic fields is on the nervous system. Possible effects could be sleep disruption. This can lead to illnesses associated with sleep deprevation.
If given a choice I would not live in close proximity to HT power lines.
Nigel Waterhouse
n_a_waterhouse@hotmail.com
A licensed aircraft mechanic and graduate engineer. Attended university in England and graduated in 1996. Currenty,living in British Columbia,Canada, working as a design engineer responsible for aircraft mods and STC's.
http://www.thomaregister.com
for more info and a potential manufacturer.
http://www.thomasregister.com
and type "High Voltage Probes" under Product / Service, which will return 6 Companies to choose from
