Induction motor in explosive atmosphere
does anybody know in which IEC standard says it is possible to use induction motors in explosive atmosphere?
RE: Induction motor in explosive atmosphere
IEC/EN 60079-7
to name a couple. The suffix will change depending on the spec required but check out the new ATEX guideline 94/9/EG, ATEX 95 as this provides an umbrella Directive to all the standards for motors in hazardous environments.
the company switched from VOC to water solvent inks and lack of maintenance on the 240V single phase ink pump motor portable cables resulted in one dead by electrocution.
ask your self what is the worst that could happen.
