Photoworks problem
Photoworks problem
Hi all,
I've hit a bump in 2008 where when i use a custom made material with a satin finish, and i select accurate reflections. some options that are in 2007 are no longer available. Specifically the ability to adjust difuse brightness and specularity. My material now is way to dark, and i cant brighten it up. If i adjust difuse and environment, all my other parts look bad. Is this a bug? or am i missing something. thanks in advance.
Tony
Tony
RE: Photoworks problem
Dan
www.eltronresearch.com
Dan
Here's hoping for some good news.
Jeff Mowry
www.industrialdesignhaus.com
What did you dream? It's all right--we told you what to dream.
--Pink Floyd, Welcome to the Machine
ht
Jeff Mowry
I actually fixed the problem. Apparently there is a problem with the old material being 2007??? I took a 2008 satin based material and just changed some settings like color, to match my old material, and all seems to be well. Not sure why i didnt think of that b4... :)
Dan
Jeff Mowry
Dan
here is what the finished render looks like if anyone would like to see.
https://home.comcast.net/~anthony.vitale/assy.tif
My thoughts anyway.
Rob Rodriguez CSWP
www.axiscadsolutions.com
www.robrodriguez.com
http://designsmarter.typepad.com/rob_rodriguez/
Eastern Region SWUGN Representative www.swugn.org www.nvtswug.com
SW 2007 SP 2.0
Jeff Mowry
Jeff Mowry
