Delrin AF vs Teflon vs UHMWPE
Delrin AF (15% PTFE filled delrin) is often used (tapped)to make nuts for precision metal leadscrews on small mills and lathes. Would it not be best to simply use pure (teflon)PTFE? What about UHMWPE? Its apparently has similar properties to teflon but less resistant to abrasion.
The goal is, the tightest fitting nut with the least friction/stiction. Delrin AF definitely beats brass for fit and wear but Im curiuos if teflon or UHMWPE are even more suitable.
RE: Delrin AF vs Teflon vs UHMWPE
Delrin is very strong. PE and PTFE are quite weak in comparison. The threads might not wear, but they might strip or be cut by harder particles.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
