nxopen .net selection
there are interactive selection methods: selectobject etc,
but If I want to select for example  some components in assembly by program without asking user...how can I do it?
RE: nxopen .net selection
 Umpteen ways to do it...
  1. Get the root part occurrence
  2. Get child ocurrences from the root occurence
  3. loop and filter the components by name/attribute/ref set/component group
The problem is I don't know how to select object without user dialog ..
method "selectobject" opens dialog for selection
I don't need this dialog...
I need to add object to selection without dialog...
could You advice which method should I use?
I'm studying at the moment "AddToSelList" but can not find good explanation of it...
