Job Descriptions
Job Descriptions
I am curious what the difference is between a Designer and an Engineer in the Power Systems Field. (Both Electrical)
My apologies if the answer is trivial, but my company uses both titles, however treat them as interchangable. No one can answer me either as to what eachs role is and how its different then the other.
Thanks in advance.
Thanks in advance.
RE: Job Descriptions
In your case a designer might be the person who can do the specing and layout of facility electrical stuff. You'd require a PE to sign off on all the stuff but the designer would do most the work.
Keith Cress
