Mechanical (stamping) Press Standards
I was wondering if there is a national, or international standard for press manufacturers tolerance specification. An example would be deflection testing for the ram and bed or flatness. At 196 inches in length you would be allowed so many thou per foot. Like DIN standard I am wondering if one exist for presses. Is there a governing body that overlooks this such as ANSI or JISC etc. If so who and where could I acquire that information.
RE: Mechanical (stamping) Press Standards
ASME B5.49 Glossary of Power Press Terms
ASME B5.52 Power Presses: General Purpose, Single-Point Gap
Type
ASME B5.55M Specification and Performance Standard, Power
Press Brakes
ASME B5.61 Power Presses: General Purpose, Single Action,
Straight Side Type
ISO 6898 Open Front Mechanical Power Presses - Capacity
Ratings and Dimensions First Edition
ISO 6899 Acceptance Conditions of Open Front Mechanical
Power Presses - Testing of the Accuracy First
Edition
ISO 8540 Open Front Mechanical Power Presses - Vocabulary
First Edition
ISO 9188 Machine Tools - Straight-Sided Single-Action
Mechanical Power Presses from 400 kN up to and
Including 4 000 kN Nominal Force - Characteristics
ISO 9189 Machine Tools - Straight-Sided High-Speed
Mechanical Power Presses from 250 kN up to and
and Dimensions
That should get you started.
If you need many, it might be worthwhile to investigate one of the clearinghouse type services that has access to a multitude of standards organizations and can offer you a one stop shop for all your standards needs.
