Tangent Edges on individual parts in assembly drawings
Is there a way to hide tangent edges on certain parts in assembly drawings while showing tangent edges on other parts in the same view? As far as I can tell you can only show/hide tangent edges for an entire view. I would like to show/hide tangent edges on individual parts. Is there a way?
RE: Tangent Edges on individual parts in assembly drawings
But,
If you make a custom template and set the option to remove tangent edges in Drawing views. Then everytime you make a new drawing those edges will not show unless someone changes that option.
I hope that helps,
Scott Baugh, CSWP
credence69@REMOVEhotmail.com
http://home.insightbb.com/~scott.baugh/
Move your cursor around the view, the solidworks dynamically shows edges, right-click and tell 'Show Edges'. You can also change the linetype style. But this is labrourious method.
