Dimensions to hidden lines ?
Hi all, I have a quick question about dimensions? I am running Solidworks 2007. In drawing views, is it possible to dimension to hidden lines? I know I used to be able to do it in earlier releases of Solidowrks but I can't seem to figure it out on 2007.
Thanks For any help.
Dave
RE: Dimensions to hidden lines ?
Tools->options->display/selection->selection of hidden entities.
Jeff Mirisola, CSWP
Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
Dim to hidden lines is against drafting practices anyway. For a clearer dwg, you may want to section the view first then dim it.
Chris
SolidWorks/PDMWorks 08 1.1
AutoCAD 06
ctopher's home (updated 10-07-07)
ctopher's blog
Jeff, I tried "Tools->options->display/selection->selection of hidden entities." Still doesn't work...Won't even allow my to select the hidden line.
Chris, I knew someone would correct me about dimensioning to hidden lines. My current place of employment doesn't realy follow propper drafting practices & standards. They are able to get away with it because all fabrication & assembly is done in house. It seems the more views I put onto drawings, the more confused our fabricators get....I know it isn't the correct to dimension, but I've been indoctrinated into the "Garvey" way.
Thanks for the help guys.
DAve
The Tools > Options > ... worked for me. (SW07 SP5)
Are you sure the Allow selection in wireframe and HLV modes option is check marked?
Do you have any Selection Filters Activated?
Have you tried re-starting SW?
cheers
Limey, "Allow selection in wireframe and HLV modes" That did the trick! Thanks I appriciate the help!
Dave
Thanks for the star, but that solution was what [b]JMirisola[b]s' post was referring you to!
cheers
