AutoTurn Roll-off and front load trash truck dimensions
Hello, I'm new here but I am currently looking for dimensions to create a truck in AutoTurn for Roll-Off dumpster trucks as well as front load dumpster trucks. Typical steering angles as well as lock to lock times would also be of great assistance. thank you.
Josh
RE: AutoTurn Roll-off and front load trash truck dimensions
Call a couple trash haulers. They should be able to tell you what is needed and give you dimensions.
Richard A. Cornelius, P.E.
WWW.amlinereast.com
Thanks for the reply. I had sent out a few messages but could never get a good contact number or email address to send in my question where it could be completely answered.
I ended up just roughing it and I guess it will be good enough for now, mostly just had to guess at the steering angle and such. I grabbed the wheel base from trucks that were listed for sale and then the rest of the trucks dimensions from the manufacturers spec sheets. Guess it will be close enough.
Try the yellow pages in your area. Then call by land line. some people don't like the new electronic media contact methods.
WWW.amlinereast.com
