HEC 2 (version 4.6) error message
Below I have retyped the error message that I am receiving.
174.95 - ERROR - GR RECORD - STA = 227.00 228.00 BT LOW CORD DOES NOT INTERSECT GR PROFILE AT DEFINED GR POINT
174.95 - ERROR - GR RECORD - STA = 227.00 228.00 TOP OF ROAD DOES NOT INTERSECT GR PROFILE AT DEFINED GR POINT
THE FEMA LIBRARY DID NOT HAVE THE ORIGINAL HEC2 DATA ELECTRONICALLY SO I AM STUCK INPUTTING THE DATA MYSELF.
THE ORIGINAL ANALYSIS WAS DONE IN 1977. I WAS WONDERING IF THE 2 HEC2 (OLDER VERSION AND MOST RECENT VERSION) VERSIONS WOULD OUTPUT THE SAME RESULT?
ALSO, CAN I JUST INPUT THIS DATA IN HEC RAS INSTEAD OF RECREATING IT IN HEC 2?
THANKS,
CHRIS
THANKS,
CHRIS
RE: HEC 2 (version 4.6) error message
I am pretty sure you should be able to import this directly into HEC-RAS. Have you tried?
tsgrue: site engineering, stormwater
management, landscape design, ecosystem
rehabilitation, mathematical simulation
http://hhwq.blogspot.com
