Chamfer Edges
Chamfer Edges
I would like to put a chamfer on 2 edges of a part (not a sketch). And need to use the distance-distance method.
The problem is that the different distances aren't being applied to the correct sides of both edges.
Edge 1 is correct, but edge 2 has the distances going to the opposite sides that I need.
Is there a way to select Edge 2 and 'switch' the directions of distances so that they go in the direction I need?
I am pretty sure this can be done, but I can't remember or figure out how to do it.
Otherwise I can create separate chamfers for each edge.
Thanks for the help.
(SW 2007 SP4)
(SW 2007 SP4)
RE: Chamfer Edges
Or create separate chamfers as you stated.
RE: Chamfer Edges
RE: Chamfer Edges
Thanks for the information.
