How to do spring back analysis in Abaqus 6.7
Hi!
I'm trying to do spring back analysis on a tube that I bend using Abaqus Explicit.
I have tried just to make the bending mandrel bend the tube to 50 degrees, and then take it back to zero degrees, but the profile will then start oscillating.
What I need to do is to get the stresses from the last timestep in the explicit analysis, and use this as input stresses for a standard implicit analysis.
Anyone got any tips/hints?
Kristian
Kristian
RE: How to do spring back analysis in Abaqus 6.7
Martin Stokes CEng MIMechE
However I still have some problems.
I took the input file with the IMPORT command from the example and tried to use it on my own analysis.
However when I try to import this file into Abaqus CAE it will open as a new model and give this message:
"The model "boyetest_statisk_import" has been created.
WARNING: Empty part PART-1. This occurred while reading keyword options within part definition.
WARNING: Part instance PART-1-1 references an empty part. A new part named PART-1-1 will be created from the mesh data in part instance PART-1-1.
WARNING: Empty part instance PART-1-1. This occurred while processing part PART-1. Neither the original part nor the part instance PART-1-1 contain mesh data.
I was thinking I should get this as an additional step inside the original model.
I've also tried just to make a new step in the original model, but it will only allow me to make Explicit Dynamic steps and not Standard Static as I need.
Kristian
Section 16.6 covers the transfer of results between Explicit and Standard. Might be worth your while to have a read through that first.
To be honest, the input deck for a springback analysis will be quite small. All you need to do is add the *INSTANCE and *IMPORT for each part you need. The *STEP required will be just a single *STATIC step. The only trick is to make sure that the model is sufficiently constrained to prevent any rigid body motions.
See the attached file for a fairly typical springback that I did on a previous Explicit forming step.
You can't mix Standard and Explicit steps in a single analysis - that's why you need the *IMPORT functionality.
I've been looking some more into the input files, both my own and yours to try to figure out how to use this.
Am I right I need to run the spring-back analysis from the command prompt, "abaqus job=springback" if I call the new input file springback.inp?
I have attached my input file for the first (Explicit) part of the analysis and this runs fine and bends the tube.
Then I have now used your input file for springback which I have modified to this:
** Decatur die necking
** Stage 1 springback
*assembly, name=Springback
*instance, instance=FE_MODEL, library=boyetest4_2_cae
*import, update=yes
*end instance
*end assembly
*Boundary
BC_BAKKANT, 1, 1
BC_BAKKANT, 2, 2
BC_BAKKANT, 3, 3
BC_BAKKANT, 4, 4
BC_BAKKANT, 5, 5
BC_BAKKANT, 6, 6
*step, nlgeom
Die Necking Stage 1 Springback
*static
0.01,1.0
*output, field, variable=preselect
*output, history, variable=preselect
*restart, write
*end step
Am I right that the IMPORT function will import all the node- and element sets from the first analysis, so I can directly refer to those when setting the boundary conditions as I have done here?
The spring back analysis still doesn't work, so I guess there are something wrong in the code above. I'm really new to this way of working with a FE system, have mostly used GUI systems before.
Also when using the IMPORT as it is done in this case, I guess it will import the whole model geometry and not only the tube which is what I really wanna look at.
I guess I have to use the *IMPORT ELSET and/or *IMPORT NSET function but find the lack of examples in the documentation kind of hard, as is's not easy to get it how to use the different parameters properly. I only want to import the elements and nodes. The elements of the tube are defined by element set NX_2D_MESH(1), and it's nodes from node set ROR. The only boundary conditions that shall apply are all six degrees of freedom is locked on node set BC_BAKKANT.
Again thanks for your help, and I understand if I'm asking a bit too much now, but I'm quite stuck with this.
Kristian
Having looked at your original input deck, you will need to change the following in the springback analysis;
- The assembly name must be the same for both input files. In your explicit deck it is NAME=Assembly and in the springback analysis, NAME=Springback - this won't work. Make it NAME=Assembly.
- I didn't have any contact in my input file. If you have any in yours, you will need to add in the required *CONTACT PAIRS. Remember that general contact is not available in Standard!
And yes, you will have to run the job from the command prompt.
I have now removed initial temperature from input file, and made the materials more simple not temp. dependent as the springback.inp analysis wouldn't work with the init temp setting.
I can now open the Springback.odb file into CAE and I will see the deformed geometry from last step in the explicit analysis. Which is a good step in the right direction :)
The analysis will run if I don't set any BC's, but it will of course not converge so it exits with error.
When I try to set BC's I also get this message in the .dat file:
***ERROR: in keyword *BOUNDARY, file "Springback.inp", line 15: Unknown
assembly node set BC_BAKKANT
***NOTE: DUE TO AN INPUT ERROR THE ANALYSIS PRE-PROCESSOR HAS BEEN UNABLE TO
INTERPRET SOME DATA. SUBSEQUENT ERRORS MAY BE CAUSED BY THIS OMISSION
Later on I also get these errors:
***ERROR: NODE SET "ASSEMBLY_BC_BAKKANT" HAS NOT BEEN DEFINED
***ERROR: A BOUNDARY CONDITION HAS BEEN SPECIFIED ON NODE SET
"ASSEMBLY_BC_BAKKANT" BUT THIS NODE SET IS NOT ACTIVE IN THE MODEL
The IMPORT command also seem to import the whole geometry. I've tried to make it import only the elements I want with putting the *IMPORT ELSET command after the import, but did not seem to work either.
Quite a few things wrong still :)
In your *IMPORT statement, the instance name is;
so,
*boundary
BC_BAKKANT
...etc
should be;
*boundary
FE_MODEL.BC_BAKKANT
...etc
You must reference the instance if it is an instance level node set. You are trying to reference a non-existant assembly level node set, hence the error.
I've now managed to run the spring back analysis :)
I had to change my first analysis file and separate the mesh into two parts one for tool and one for tube/blank.
This way I was able to just import the tube instance when doing spring back analysis.
However I was still not able to use the nodeset BC_BAKKANT for setting the boundary conditions in the new input file, so I had to manually define this nodeset again in the springback input file. After I did this the analysis did run fine :)
When I refer to the existing nodeset in the BC (ROR1.BC_BAKKANT) I get this message (The instance name of the tube is now ROR1):
***ERROR: in keyword *BOUNDARY, file "Springback3.inp", line 391: Unknown part
instance node set ROR1.BC_BAKKANT
Further down I also get this:
***ERROR: NODE SET ASSEMBLY_ROR1_BC_BAKKANT HAS NOT BEEN DEFINED
I guess this must be due to a small issue in my code.
*HEADING
** Spring back analysis of tube
*ASSEMBLY, NAME=Assembly
*INSTANCE, INSTANCE=ROR1, LIBRARY=boyetest4_4_cae
*IMPORT, STATE=YES, UPDATE=YES
NX_2D_MESH(1)
*END INSTANCE
*END ASSEMBLY
*BOUNDARY
ROR1.BC_BAKKANT, 1, 1
ROR1.BC_BAKKANT, 2, 2
ROR1.BC_BAKKANT, 3, 3
ROR1.BC_BAKKANT, 4, 4
ROR1.BC_BAKKANT, 5, 5
ROR1.BC_BAKKANT, 6, 6
*RESTART, WRITE
*STEP, nlgeom
SPRINGBACK
*Static
0.05,3.0
*OUTPUT, FIELD, VARIABLE=preselect
*OUTPUT, HISTORY, VARIABLE=preselect
*END STEP
Thanks for any help and merry christmas :)
Kristian
