Insert Excel Spreadsheet?
I'm trying to insert an Excel spreadsheet into an AutoCAD dwg. (2008 LT)
All I get is a small portion of it. As a matter of fact, if I try to insert it as a WMF, it's the same thing. Is there any way to get the whole spreadsheet to show in the dwg? Thanks.
RE: Insert Excel Spreadsheet?
Mike Halloran
Pembroke Pines, FL, USA
Highlight the range of the spreadsheet you want to insert > Copy (Ctrl+C).
In Acad... File > Paste special > Paste (or Paste/link) as Autocad Entities. The spreadsheet will come in as a Table.
____________________
Acad2006, Terramodel
I have used MSPaint as a work-around. Perform a print screen of the spreadsheet and save to MSPaint. Insert the bitmap file in the drawing. The size of the spreadsheet could be a limitation with this method.
Good Luck
Don Phillips
http://worthingtonengineering.com
