How to make a run on an old braked dyno.
I am having problems understanding how one could make a dyno pull from low engine rpm to high engine rpm at full throttle on an old braked(telma) chassis dynamometer.
What should be done to the brake when making such a pull.
Could someone give a hint?
RE: How to make a run on an old braked dyno.
Cheers
Greg Locock
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
Go with the car to full throttle and then release the brake (setting to a higher km/hour) in steps until fully released.
I suppose at each step I should give the dynamometer the time to reach it's setpoint and then read the it's hp at the wheels.
In this way I should then get a hp curve that normally increases as I release the brake (setting for a higher km/hour).
Is this correct?
I haven't used that sort of dyno. The one I've used most recently is electrically controlled, so I can either run in speed control mode or force controlled. In the latter you just sit at cruise and then wind the force up until you have full throttle at the same speed, and then play with it from there.
However I don't use this dyno for power measurements, there may be better approaches.
Cheers
Greg Locock
This takes some judgement, like throttle and clutch control when doing a hill start.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Great learning experience though...
My approach is to monitor the roller speed and compare that with a set reference speed, and use any resulting error to drive a dc current through the windings of the Telma eddy current retarder.
If the rollers are running slow, there will be no retarding action at all, so the vehicle can be brought up to the required speed by just opening the throttle. As soon as the set speed is reached, the Telma will then provide enough torque resistance to hold the set roller speed. As you open the throttle further, the roller speed remains constant.
That way you can map your fuel and ignition at a range of throttle openings at any desired fixed engine rpm.
To do a sweep test, as you are suggesting, just cause the set target speed reference to ramp upwards at a suitable rate. The vehicle will follow that rate of speed increase.
You can then go wide open throttle, and the speed will increase at whatever speed the reference speed increases. The Telma retarder will hold the engine to a constant rate of acceleration, whatever shape the torque curve happens to be.
