Grouting level for the Baseplates of KSB pumps
In my projects I have 9 KSB horizonal booster pumps, MULTITEC Type, the manufacturer's recommendation for installing the pumps baseplates call for the following :
Text : "shims shall be fitted between the baseplate/foundation frame and the foundation itself.For bolt-to-bolt clearance > 800mm, additional shims shall be used. Baseplate more than 400 mm wide shall be grouted up to the upper frame edge using low shrinkage concrete"
All the 9 pumps have baseplates of more than 400mm wide, My concern is about the final level of grouting. Is the upper frame edge mean the same as the upper level of the baseplate ? I'm confused because after grouting the whole baseplate to the top it will be fixed for ever ? I attached a photo for the pump showing the level that I think grout should reach it ? Please confirm to me the level of grouting ????
Thnaks
Thnaks
RE: Grouting level for the Baseplates of KSB pumps
If you need to uninstall it, that is why they make jack hammers....
"Why don't you knock it off with them negative waves? Why don't you dig how beautiful it is out here? Why don't you say something righteous and hopeful for a change?" Oddball, "Kelly's Heros" 1970
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
So fill 'er up!
Mark Hutton
