How source xls file in postprocessor
Hi All
How to source the xls file in postprocessor
I want to source speed and feed parameter to xls file
RE: How source xls file in postprocessor
I don't have much idea how you would to the later, but if the question is clear somebody may suggest some kind of work around.
If you want to get the speeds and feeds out of the post for documentation purposes then does the Shop Documentation that NX produces not work or not provide enough information?
Hudson
