apply load till fail
Hi all forum,
I am doing a modeling of a steel I-Beam, I would like to apply load on the beam ( say 5kN increment, each time) till it fail in vertical shear. How to tell Abaqus to do this? should i use the 'step module'? please advice.
RE: apply load till fail
You should define something like this:
Step1-Load0-5
Step2-Load5-10
Step3-Load10-15
etc.
Further, you must edit the load magnitude for each step.
If you are not familiar with ABAQUS/CAE, I recommend you start with this tutorial:
"Getting Started with ABAQUS" Manual (v.6.6)->
2.3 Example: creating a model of an overhead hoist with ABAQUS/CAE
