How do I disable the "Layer Properties Manager" popup?
I would like to stop the popup Layer Properties Manager because I can type the commands more quickly than I can select them. Anyone know if there's a variable I can turn off?
RE: How do I disable the "Layer Properties Manager" popup?
AutoCAD antique commands are usually prefixed with '-'. Type "-layer" instead of "layer".
Thank you! So simple!
a shorter line command version presented by vlh75 "-la"
