Davit / Lifeline Connection
From CFR 29 1910.66 Appendix C states:
"(2) The anchorage should be rigid, and should not have a deflection greater than .04 inches (1 mm) when a force of 2,250 pounds (10 kN) is applied."
http: //www.osha .gov/pls/o shaweb/owa disp.show_ document?p _table=STA NDARDS& ;p_id=9730
How do you interpret this? This is an extremely tight tolerance.
http:
RE: Davit / Lifeline Connection
