RO reject water pipe material
What is the best type of pipe material to use for RO reject water?
RE: RO reject water pipe material
The water made by RO is missing an ion (cannot remememer whether positive or negative) Anyway it attempts to grab back this ion on the discharge piping (ie corrosion). Best practice is to make your discharge piping of PVC.
Offshore Engineering&Design
David
It has high strength and has a higher fracture toughness than PVC. Also the solvent cement joint integral bonds the two ABS surfaces. Whereas the "glue" used for PVC can be seen when you section a joint.
Eurapipe is a Tyco compnay represented in most countries in this region. ABS is being used in major projects in the Middle East.www.tycowater.com/plastic_pipeline_systems
