FINDING DUPLICATE GEOMETRY
IS THERE A SIMPLE WAY TO LOCATE DUPLICATE GEOMETRY IN CATIA
RE: FINDING DUPLICATE GEOMETRY
This scenario assumes you are searching for duplicate surfaces. Start making a "Join", give it a coarser tolerance than the default micron, and pick one face only. Then, for a better visualisation, create a boundary of the "Join" feature and maybe give it a different color. Then edit (double-click) the Join feature, and in the "Element to join" window, right-click and choose "Distance propagation". Whenever you have two identical faces, chances are that you will be given the "Fork" message, meaning that the system doesn't know which way to propagate. The missing portions (shown by the boundary and/or the different colors) you have to add manually...
Whenever you have the joined surfaces with only one outer boundary (or with no boundaries if you close a volume), you can erase all the other surfaces that don't make up the Join feature, they are duplicate geometry.
Hope that helps.
Best regards,
Stely
You can use the shading parameter View / Render Style / Customize View : Line on line...
it might help.
