VFD Noob, Hitachi J300 input confusion
Got a great deal on a Hitachi J300 inverter, using to control a 5hp gear motor for feedworks on a planer.. need to use the forward, reverse, free run stop, and jogging.. also control speed via 1K ohm pot..
I have the pot connected and working, but.. the inputs for FWD/REV/JG/FRS arent working as described in the manual:
http://w ww.hitachi .us/suppor tingdocs/f orbus/inve rters/Spec ifications /J300U_Ins truction_N B506XC.pdf
all inputs are set up for a NO connection, and needs a 24V input for 20ms, however, when the 24V is supplied, it wont 'pick up' the input, and the 24V needs to stay supplied at the input for continued operation.. this is the same for all inputs, FWD, REV, JG and FRS..
other inverters I have here dont require a closed connection, and from what I can tell from the J300 documentation, that should be the case with this inverter as well..
any help would be greatly appreciated.. probably something in the programming I'm overlooking, or a flaw in my external circuit? at this point I'm just benching it and using a jumper from the internal 24V supply to the inputs.. anyhow, thanks in advance!
http://w
RE: VFD Noob, Hitachi J300 input confusion
Not too familiar with the Hitachi J300 but I think this could be where your problem lies.
I'll keep poking around until I get it to work, and will keep the topic updated
any other ideas would be greatly appreciated!
Keith Cress
