Right type of Battery
Currently I'm using two 12 volt Lead Acid batteries to power a solar boat, rated at I believe 30AH combined. I'm strongly looking into Lithium-Ion batteries to save weight(about 40 pounds). I'm curious to know however, do the 12v Lithium batteries equal the voltage of the Lead-Acid which charge to almost 13 volts? I've been doing a lot of research on different types of 12 volt Lithium, and would love any information on a cheaper source for them. I need at least a 30AH rating, more would obviously be better, using 2-4 batteries. Is a maximum price of $200-300 per battery too much to hope for? If it is would NiCad be the best way to go?
RE: Right type of Battery
Also, you might consider NiMH batteries.
