Section E.6.1.4, API 650
I noticed that the coefficients on the equations for Ni and Nc have changed between Addendum 4 of the 10th edition and the 11th edition.  Does anyone know the reason for the change and what effects the changes have on the calculated loads?
Also, in equation E.6.1.4-4B two new variables are included in the equation.  They are Cc and S.  I can not find where these are defined.  Are they in there and I am just overlooking them?
RE: Section E.6.1.4, API 650
Sounds like an inquiry to API would be in order on this one.
If the values are correct it will increase the combination stress from seismic and liquid. I asked API this question along with several others on the seismic and was told that there are corrections to these coming in the Addendum 1 to be released in January.
January of which year?  API is notorious for missings schedules bigtime.  My guess is January 2009!!!
Joe Tank
