Include Liquid in Overturning?
I have a question regarding tank design per API-650. I have a small (30 ft OAH x 12.5 ft OD) tank that is shop fabricated. The tank is in a very high wind zone, and I am verifying that the tank is adequate for overturning. My question is whether you must consider the tank to be empty (no liquid) when calculting overturning? If there is a minimum liquid level in the tank, is it acceptable to consider that this liquid is present when determining the overturning?
RE: Include Liquid in Overturning?
Yes, consider an empty tank coincident with a wind gust.
The calculation that you are making, of course, determines the need for anchor bolts
As a general rule of thumb, IMHO, I would require anchor bolts on a tank whenever the shell height exceeds the diameter.
-MJC
I'm looking at API-650 (11th Edition - June 2007) Para 5.11, and I don't see anything about how much liquid to assume for an anchored tank?
Typically, overturning stability of a foundation would not include any allowance for product- it would be based on empty weight.
API added the uplift on the tank roof, which tremendously increases the overturning of many tanks. At the same time, they added the allowance for product, which counteracts much of the increase.
Note that if you calculate the overturning moment about the edge of the tank per API-650, this is not the same as the overturning about the centerline of the tank that would be used in Mc/I-type calculations for bearing.
