Importing text or xls files into a drawing
I have a drawing and would like to place and Excel file in the drawing. Is this possibe and how can it be done???
Thank you and Merry Christmas,
Danoo
RE: Importing text or xls files into a drawing
One way is Insert>Object then it will show what object types are available on your particular pc
default will look in your work directory when you load a existing file ..or there is create new which is default
and then to get it where you want window it in and move special....
colors are kind of bogus.. can be linked for update to.. there's a faq on this I think..
hth
I'm not a real big fan of excel, I'm sure someone will add in some tips on how to make it a little better looking
