A poor man's right angle drive?
Gents;
I have an agricultural application that requires the output from a small (50 hp) tractor engine to be delivered at a (horizontal) right angle to the engine drive shaft and then, through sprockets, to the chain driven machine. No gear reduction is required. Something suitable for a driveshaft input speed from 1000 RPM to 4000RPM continious duty is required.
Is there any reason I shouldn't try a regular automobile rear end differential? I would fix one output shaft stationary thus requiring all the all the power to be delivered to the other shaft. Most auto differentials have a 1:2 to 1:4 gear reduction but I can step it back up by selecting an appropriate size chain sprocket. What are the pitfalls in this scheme? Other than immobilizing and securing the one output shaft, what other modifications should I make? Your thoughts would be appreciated.
If this plan proves un-workable a PTO right angle gear box will have to be used. Here is a link to an outfit in Austrialia: htt p://www.ba reco.com.a u/files/pt o2002/selg earbox.htm . I've searched high and low on the Internet for a USA distributor/manufacture of this kind of gearbox with no joy. Can anyone supply a link?
Best Regards
Ken
Best Regards
Ken
RE: A poor man's right angle drive?
How does one "lock a differential"?
I thought I would have been doing that by immobilizing one of the output shafts. I must have been wrong though.
Best Regards,
Ken
A buy a spool or mini spool and install it
B do some welding of spider or side gears
C pour the spiders full of lead or aluminum
locking 1 axle on an open differential will cause the spiders to behave like planetary gears increasing wear but also cutting the reduction in half ( 4 to 1 becomes 2 to 1 ) if its well lubed and lightly loaded that could work for you.
good luck
Mike Halloran
Pembroke Pines, FL, USA
Thanks for the tips and explainations.
This weekend I'm heading for a salvage yard in search of a cheap auto differential that I can take apart to see whats what inside. With an illustration in hand I guess I can figure out what is a "spider gear" and what is a "side gear". I'll see what happens when I "freeze" up a particular gear as if it were welded per FoMoCoMoFo's suggestion.
As I understand it, a "frozen" differential will result in a right angle drive with two output shafts both going in the same direction at the same speed. (i.e.: both "top going" or both "top coming" when viewed from drive shaft.)
My guess is that a differential from a independant rear suspension car would be more compact and be best for this purpose.
Thanks again for your advise.
Best Regards,
Ken
http://
http://auto.howstuffworks.com/differential2.htm
Strategic placing of pieces of the shaft of an old bolt can greatly increase the strength of the welding.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
www.retallickeng.com.au
Was told it couldnt be done, so
i went and did it!
I myself have converted a large mid-mount finish mower to a frontend loader offset mounted unit using hydraulic power. Its a 50 HP application. You can ratio the displacements to get the rpm of the attachment you need; no chains, sprockets or extra shafts. And, you get the flexibility of mounting location and angulation.
Yes you'll need a reservoir, relief valve, pump, motor, hose and some connectors. Maybe the tractor hydraulic supply can be utilized. You end-users will appreciate the much simpler mchanism. Mowers, hole diggers, rakes, combine heads and many other systems have given up the mechanical driveline (some needing constant velocity joints) in favor of fluid power delivery.
You didn't say, but if you're being paid to design and build this device, why don't you do the professional thing and design a proper gearset to do the job right. Will your customer be satisfied with cobbled-together junkyard parts?
If instead, this is just a garage project, for your own use, buy a new aftermarket, heavy duty, hypoid R&P set, and machine your own (steel) housing to fit your equipment.
Be careful to provide adequate bearing support for the chain sprockets. Especially if they're cantilevered.
It's for my Father-in-law. I have access to a welder, drill press and metal cutting band saw. I don't have access to a lathe, milling machine or gear hobber. Therefore, I'm putting this thing together (as much as possible) with off the shelf components including pillow blocks, sprockets, power transmission chain, ground round stock, CV joints, adapters and sleeves. Most of these items are readly available at industrial/agricultural supply houses. And, being stock items, are quickly and inexpensively replaced when they wear out.
Chain drive and CV joints are very tolerant of the inevitabile lack of precision and general mis-alignment. Shims will take of the rest. I'm not designing a Ferrari, here.
Thanks for your reminder about "bearing support". I'll be sure to include a pillow block to support the outboard end of the final drive chain sprocket shaft to take care of the overhung load.
Best regards,
Ken
I've also used the term Lincoln Locker (Lincoln Welders)
