Air compressor
3
Air compressor
Air compressor
Hi All,
I’m looking for air compressor which has:
Air displacement:        30 L/M
Max Pressure:            8  bar
Noise level:             65 dB
Where can I find it?
Thanks,  Aharon
RE: Air compressor
Try going to Grainger dot com for your air compressor and blower.
They have a lot of stuff.
RE: Air compressor
Try Thomas or Gast
RE: Air compressor
 ATLAS COPCO, GOT A LARGE CHOICE.
Offshore Engineering&Design
RE: Air compressor
You left out something... Gas powered? electric? Need a tank?
Have you done an internet search? There's a thousand manufacturers.
That also only equates to 1cfm, and 116 psi.
Is that volume correct?
David
RE: Air compressor
sears or harbor frieght
