max velocity in pipe 30''
We have a crude tank with a 30'' valve at the exit. This line will be the suction of the pump.
My process engineer limit the velocity in the 30'' pump suction line at 4 ft/s.
What do you think ? It is to conservative. I read usually it is between 6 and 10 ft/s.
vladimir99
vladimir99
RE: max velocity in pipe 30''
If you need information on this try www.mcnallyinstitute.com for technical papers on NPSH.
Geoffrey D Stone FIMechE C.Eng;FIEAust CP Eng
www.waterhammer.bigblog.com.au
http://virtualpipeline.spaces.msn.com
