getting an error trying to create cross sect. with new finished grade
"Design surface contains less than two points."
Does anyone recognize this error, I have been able to get my existing grade to show up, but my new finished grade will not, I am assuming it has something to do with this error. I'm not sure if it's my alignment, profile, or surface?
RE: getting an error trying to create cross sect. with new finished grade
Try building the surface and see if that works. Then maybe see if the site is set up right.
