NX3/winXp, Crosshatching question
Another question about one of our tedious tasks.
We usually have to add a view on our drawings showing what areas of the part gets bonding. How we achieve this is by expanding the view, extracting lines, back to the drawing and adding crosshatch to the view (using the lines we extracted or silhouette curves the drawing extracts).
This is a huge time sink. We have to redo the cross-hatch a lot, from small minor updates to major updates to the part.
Anyone have any ideas, or deal with this that can maybe shed some light.
Thank you.
Thank you.
Justin Ackley
Designer
RE: NX3/winXp, Crosshatching question
Justin Ackley
Designer
However, with simpler defined areas I might define the boundaries of target regions as curves, especially if edge curves aren't going to be available in the solid model for example. Where we differ is that I'd try to do this in modeling space, on a separate layer from the model. I would create the drawing mostly with just the model visible, and in the view or views where you need to call up the affected regions make the layer with the curves visible, and then use them for the hatched regions.
In order to make the regions very easy to maintain you can try using the join curves command to create a closed boundary, because it will only take one selection to crosshatch. If you create the boundary with curves or lines that you may later wish to change then why not place them on their own layer that stays hidden. then keep the joined curve associative to them. All this may sound somewhat complicated, but it sure is easier to maintain than anything that involves picking and re-picking crosshatch boundaries in drafting.
As for the hatching itself, it lives on the drawing, (i.e. expand member view is not used). Others may differ, but I find this method easy and works for me.
Best Regards
Hudson
