Post tensioning concrete program
What are good post tensioning concrete design programs in used today?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
Post tensioning concrete programPost tensioning concrete program(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Post tensioning concrete program
I use RAPT (www.raptsoftware.com) and have done so for several years. RAPT does 2D (not FEA) analysis and design of RC and PT floor systems to many international codes, and you can actually create your own "code" since the user has full control of the defaults and assumptions etc.
RAPT accurately considers partial prestress designs too - and is able to handle draped, harped and straight tendon configuratins, with short, long or intermediate tendons lengths. You can also have some spans with no PT and it will undertake min. rebar as RC section.
Ultimate and serviceability conditions are comprehensively considered, and both bonded and unbonded tendons can be used. Cracked section analysis is undertaken automatically if the section is subjected to tension under working loads, and deflections include cracking effects, tension stiffening, creep, time of loading rebar layout etc. The age adjusted effectve modulus method is used.
You can also model slab/beam depressions, steps, tapers, haunches with easy to understand and quick input.
For complicated floor systems where 3D FEA is justified I use SCS FLOOR (www.concsoft.com). The input is CAD based and has an auto mesh generator. Good program but it does not do cracked section analysis (so for a partial prestress design you have to a bit of hand calcs) nor a comprehensive treatment of long term deflections.
The most important thing I have found with PT programs is that the authors are 1) structural engineers and 2) have actually designed and detailed real PT structures and maybe 3) have seen actual PT projects on a job site. If the authors are just software junkies you will get basically P/A + M/Z with some fluffy graphics.
HTH
How much does RAPT cost?
I believe the current version is US$4,000. Includes ACI-99, UBC, BS, Australia, Euro, Taiwan, Singapore, South Africa etc. Also does columns (prestressed and RC, and combinations of both) M-N interaction diagrams, of irregular shapes, with voids, too.
There is also another software ADAPT for prestressed design used extensively in practice. I have not used this software. it would be useful if someone could compare these two softwares, RAPT and ADAPT.
ADAPT-PT can design slabs (one- and two-way) and beams and has a fairly comprehensive output that will allow you to use the results in other modeling/design programs. You can design for forces (the common approach in the US) or the number of tendons with adjustments for friction losses, etc.
It has several post-processors for friction losses and suplemental reinforcement for lateral moments. It makes use of the Equivalent Frame Method and we've even used it to model some traditionally reinforced two-way slabs on small investigative jobs.
The user interface takes a minute to get used to, but the documentation that is provided is actually rather helpful. Since the program was written by and sold by the company of B. Aalami (probably the leading expert in the US) the tech support is usually pretty good.
Ram Concept relies on FEA and gives a better idea of where the stresses actually are. It can be back checked againt a EF model for consistency. In addition, Ram has indicated that in the future, all parts of its design center will be integrated making it possible to deisgn a PT parking garage, concrete first floor, and steel super structure all in one model. This is years off, but I figure it is best to be in on the ground floor and grow with the program.
http://www.adaptsoft.com/news.shtml#10
