Thermal Modelling
Thermal Modelling
Hi All,
I have a box structure measuring 3000mm x 2500mm x 2100mm. This structure has 60mm walls, floor and roof with a thermal coefficient of 0.39. - 0.49 Wm/K
If I said starting point was with an internal temperture of 18 degrees centigrade and the outside was a constant -40 degrees centigrade, how easy would it be to plot the change in internal temperature against time?
Is this something that cosmosworks can model as we have a contractor with the license
D
D
RE: Thermal Modelling
I think you need COSMOS Professional for that. But its possible.
Could anyone back it up?
Hope I helped
ZillionM
It is possible to complete transient thermal studies with COSMOSWorks Professional but not with COSMOS designer so long as you know the boundary conditions.
DKZ
