93% Sulfuric Acid Tank (Materials Selection)
For a relatively small tank (2000 gallon) I am curious what the drawbacks of 304ss as opposed to 316ss. Corrosion tables I've seen indicate 304 doesn't offer much more resistance than carbon steel, especially at temperatures over 80F-90F.
I'm interested in using a ss alloy because the tank will be of relatively small dimensions and portions of pipe will be small, exceeding the recommended limits in NACE SP0294. To prevent any dangers due to the higher velocities (wall thinning near tank inlet, accelerated pipe corossion) the ss alloy is a better choice. NACE says both 304 and 316 are adequate, but the tank will be located in ambient conditions so temperature effects may be a concern.
carbon steel may even be sufficient, but problems with corossion products in an existing system have negated this choice.
RE: 93% Sulfuric Acid Tank (Materials Selection)
S.
http://www.corrosionist.com
