Can't find "Turbocharging the Internal Combustion Engine"
I've seen Watson and Janota's book "Turbocharging the Internal Combustion Engine" refferenced in about every book and paper on engine design i've seen. My problem is that I CAN'T FIND A COPY!!!
I've tried Amazon, ebay, and countless used book warehouses. I've even called the publisher with no luck.
question:
Is this book worth the trouble to find?
Any other ideas where i can look for it
question:
RE: Can't find "Turbocharging the Internal Combustion Engine"
Change the zip to yours and you get a list.
http
Back before the net, libraries were the place to find info, I think there are still a few around.;)
If you cannot find it then the second best option is the book by Nicolas Baines "Fundamentals of Turbocharging". It contains partly the same material as in Watson&Janota but not to the same extent.
http
Cheers
Greg Locock
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
I have a copy (somewhere!)and from memory it's not for the casual reader, but it's an excellent reference that has stood the test of time. Read it and learn!
